Thunderbird Android with Outlook
  • 3 replies
  • 10 have this problem
  • 67 views
  • Last reply by Yu5tiqX9og
Thunderbird android fails to login to outlook account with automatic configuration, which also seems to be the Microsoft recommended. On android 13.
Steps: Add account > enter your_mail@outlook.com > automatic configuration > [Accept] in the webview of microsoft asking to authorise TB
Message popup: Checking incoming server settings failed Server error Server returned the following message: User is authenticated but not connected.
Thunderbird android fails to login to outlook account with automatic configuration, which also seems to be the Microsoft recommended. On android 13. Steps: Add account > enter your_mail@outlook.com > automatic configuration > [Accept] in the webview of microsoft asking to authorise TB Message popup: Checking incoming server settings failed Server error Server returned the following message: User is authenticated but not connected.
Attached screenshots
Update: No fix yet
I'm also getting the same error as in the screenshot provided above. But sometimes it does sync. Is this going to be addressed??
